Старый 08.03.2016, 21:16   #1
kurthatlevik: AX 7 RTW – My ODATA and JSON journey – Part I
Источник: https://kurthatlevik.wordpress.com/2...ourney-part-i/
Learn the word; ODATA. We will hear a lot of ODATA in the future, because it will change the way we integrate and how we exchange information between AX and other systems. A good starting point is the AX help wiki, that Kuntal Mehta created. I have decided to explore what the ODATA can do, and wanted to write a bit about my journey. Instead of trying to explain all technical details of data entities and how the architecture is, then let us rather just test something J
What you need to test what I’m doing is
  1. An AX RTW environment deployed from LCS
  2. Internet explorer
  3. Good old notepad
Step1: What services is available?
To get all entities available to you use your Site address, and add “/data” at the end.
Then save the file you receive, and open it in notepad. (I have associated *.json with notepad). The file you get looks like this:
Each line here represents a data entity service we can use. The format of this is the JSON format, but that is not important now.
Step2: Show me the customers
In the file you may find that there is an entity/schema named “Customers“. I can therefore just add the “/data/Customers” to my URL
And then I get a JSON file of all the customers;
But this is a bit “cloudy” and I can further filer down what I want. Let’s say I just want to see all customer names. I can then add “/data/Customers/?$select=Name” to my URL
Now it returns a JSON file with only the Name.
If I wanted to add one more column, like the Payment terms, the syntax would look like “/data/Customers/?$select=Name,PaymentTerms“, but this would not work because the comma cannot be used on a URL. I therefore need to replace the comma with %2C, that is the URL representation of comma. For multiple columns I therefore add “/data/Customers/?$select=Name%2CPaymentTerms
You see some strange “@data.etag”, and here is an explanation. It is for caching.
Step3: Can I read this in Excel?
Yes. Excel can import OData, and format it like we would.
Then fill in the /data URL, select schema, and then select fields.
And then you may read directly into Excel all entities made available in AX RTW, even without the AX connector.
Step5: Show me all !
Sure. Try to add the “/data/$metadata“, and AX return All schemas, fields and relations. It take a long time, but nice to explore.
Step6: Can we use DIXF to import directly from OData feeds ?
This is what I would love to see. But I have not found it yet.
Happy DAX’ing ;-)
crminthefield: How to Increase the 50 Record Page Limit on OData Retrieve Responses for Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 16.03.2012 23:12
axforum blogs: Использование OData в CRM2011 Blog bot Dynamics CRM: Blogs 0 21.09.2011 20:11
CRMScape: CRM 2011 OData, JSON and CRM Forms Blog bot Dynamics CRM: Blogs 0 08.03.2011 20:12
dynamics-ax: Microsoft Dynamics AX 2012, OData and EDM Blog bot DAX Blogs 0 02.02.2011 07:11
sanjayjain: Pervasive Data Integrator Universal CONNECT! offers OData integration Blog bot Dynamics CRM: Blogs 0 30.06.2010 02:06
Часовой пояс GMT +3, время: 09:42.
