Старый 09.03.2016, 03:28   #1
organicax: Enable price control on a call center
Источник: http://organicax.com/2016/03/08/enab...a-call-center/
If you are taking sales orders with AX then there are some nice features that will open up if you are also using the call center. One example is the price control. This will work in conjunction with a parameter on the released item called allow price adjust. Both these together will allow you to control that an operator can’t change the price on a sales line. And if you allow a price change then an operator could be prompted for a price override which could be done by a supervisor or team lead.
Here is a quick walk through.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Retail
emeadaxsupport: AX for Retail R3 CU8 Call Center: Fix for Customizing CRT Pricing Engine Blog bot DAX Blogs 0 01.07.2015 19:11
emeadaxsupport: Error Posting a Free Text Invoice when Call Center is enabled: "Payment is not authorized" Blog bot DAX Blogs 0 12.05.2015 23:12
emeadaxsupport: Enabling the new Call Center Channel User Functionality in AX 2012 R3 Blog bot DAX Blogs 0 02.09.2014 18:11
Axilicious:Hosting custom WPF calendar control in AX 2012 Blog bot DAX Blogs 0 20.05.2013 18:11
DynamicsAxSCM: Sales and purchase prices in relation to the item price setup in Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 11.02.2010 09:05
Часовой пояс GMT +3, время: 21:46.
