Старый 15.03.2016, 04:48   #1
25,644 / 848 (80) +++++++
organicax: Basic request for quotation process
Источник: http://organicax.com/2016/03/14/basi...ation-process/
There is a good amount of functionality in the procurement and sourcing module in Dynamics AX. One areas that isn’t often used is the request for quote. Even if you don’t do formal quoting and keep all the information in AX and use the vendor portal collaboration piece it could be helpful when you are doing some basic shopping for a better deal on items. While you might do a lot of work outside the system you could at least create a basic RFQ for tracking and being able to compare the options.
Here is a quick overview of a basic RFQ process.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Basic process of handling item requirement on a project. Blog bot DAX Blogs 0 14.03.2016 22:11
organicax: AX R3 Warehouse in manufacturing – end to end basic flow. Blog bot DAX Blogs 0 09.03.2016 16:11
emeadaxsupport: Adding a item to the AX R3 Online Store gives the error message "We cannot Process your request at this time. Please try again later. " Blog bot DAX Blogs 0 27.11.2014 02:34
Microsoft Dynamics CRM Team Blog: Using the Business Process Flow Designer Blog bot Dynamics CRM: Blogs 0 24.10.2013 05:13
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
Часовой пояс GMT +3, время: 03:16.
