Старый 24.03.2016, 22:12   #1
organicax: Overview of editing the CSS style sheet for the warehouse mobile device
Источник: http://organicax.com/2016/03/24/over...mobile-device/
In a previous post we looked at the basic label color display for the warehouse mobile device. If you wanted to do something more advanced then you can edit the CSS style sheet. This isn’t a user task and you are best to get someone that has some experience editing style sheets for web applications.
It’s also worth noting as I’ll point out in the video some of the label colors are injected as an in-line style from the application. So these few labels you will have to change in the warehouse mobile device text colors setup. You will have to co-ordinate these with the CSS change you make to those collections.
Here is a quick walk through.
AX2012 R3 CU9.
Cheers
Lachlan
Filed under: Uncategorized, Warehouse management
organicax: Setting up the warehouse mobile device portal for a second company Blog bot DAX Blogs 0 09.03.2016 03:28
DynamicsAxSCM: Creating Custom Solutions with the Warehouse Mobile Device Portal Blog bot DAX Blogs 0 13.03.2015 16:11
DynamicsAxSCM: Warehouse Mobile Device Portal Architecture Blog bot DAX Blogs 0 03.03.2015 19:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
dynamics-coe: Integrating Microsoft Dynamics CRM 2011 Online with Java and other non-.Net Clients Blog bot Dynamics CRM: Blogs 0 21.09.2013 13:11
Часовой пояс GMT +3, время: 00:34.
