Старый 03.04.2016, 08:23   #1
organicax: Effect of approving a planned order
Источник: http://organicax.com/2016/04/02/effe...planned-order/
If you are working with master planning you can work with multiple plans. If you have a planned order that is generated in a plan then if you run a regeneration master schedule then the planned orders will be deleted for that plan and recreated. If however you want to keep one or a collection of orders before the next master planning run then you can set the planned order to an approved status.
Here is a quick overview.
AX2012 R3 CU9.
Cheers
Lachlan
Filed under: Supply chain planning
organicax: Purchase order workflow configuration with auto approval Blog bot DAX Blogs 0 26.03.2016 04:15
organicax: Handling sales order with delivery schedule with warehouse Blog bot DAX Blogs 0 17.03.2016 01:15
organicax: Creating a coupon for a discount and using on a call center sales order Blog bot DAX Blogs 0 11.03.2016 05:17
organicax: WMS Automatically create load at sales order entry Blog bot DAX Blogs 0 04.03.2016 23:11
Часовой пояс GMT +3, время: 09:56.
