Старый 05.04.2016, 11:11   #1
organicax: AR Parameters – Period of validity
Источник: http://organicax.com/2016/04/04/ar-p...d-of-validity/
When you are looking at the sales order header there is a field called deadline that you might be able to use in your processes. This is setup from the accounts receivable parameter period of validity. Once set the deadline value will be populated and you can use this to search for orders that haven’t been processed by the dealine so you can decide if you follow them up or remove them.
Here is a quick overview
AX2012 R3 CU9
In the video I mentioned the mark order as void which you can get an overview in this post .
Cheers
Lachlan
Filed under: Accounts receivable
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
organicax: Registering vendor batch information – wms Blog bot DAX Blogs 0 24.03.2016 16:11
organicax: AX R3 Warehouse in manufacturing – end to end basic flow. Blog bot DAX Blogs 0 09.03.2016 16:11
emeadaxsupport: Adding a period to the Aging Period Definition and receive the error: "Unlimited can be used only in the first and last period" or "Unit must be less than 0" Blog bot DAX Blogs 0 29.03.2013 06:11
Gareth Tucker: Duplicate Record Button using Jscript in Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 31.07.2012 16:11
Часовой пояс GMT +3, время: 21:40.
