Старый 14.04.2016, 19:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Tips for naming your Aging Period Definitions
Источник: https://blogs.msdn.microsoft.com/axs...d-definitions/
Have you ever created your Aging Period Definitions, run the Customer aging snapshot, and do not receive any results in the Collections Grid? If so, this could be a result of the format used in the Aging Period Definition name. I have recently discovered that commas in the Aging Period Definition name are treated by... Read more
emeadaxsupport: Customer aging snapshot performance improvement approach through parallel batch execution Blog bot DAX Blogs 0 30.09.2015 18:11
emeadaxsupport: Tips for finding Microsoft Dynamics AX resources Blog bot DAX Blogs 0 08.10.2013 09:12
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting - tips how to improve performance Blog bot DAX Blogs 0 18.09.2013 17:11
emeadaxsupport: Error message “Posting definitions are required for year-end general ledger close.” in AX 2012 Blog bot DAX Blogs 0 09.06.2013 11:11
emeadaxsupport: Adding a period to the Aging Period Definition and receive the error: "Unlimited can be used only in the first and last period" or "Unit must be less than 0" Blog bot DAX Blogs 0 29.03.2013 06:11
Часовой пояс GMT +3, время: 07:47.
