Старый 30.06.2004, 07:51   #1
bm is offline
bm
Удалить закупку
Хочу удалить закупку. Будет ли такой код правильным?
Период текущий месяц,сопоставлений и списаний нет.
static void job123(Args _args)
PurchLine PurchLine;
PurchTable PurchTable;
Voucher v;
TaxTrans TaxTrans;
LedgerTrans LedgerTrans;
VendTrans VendTrans;
InventTrans InventTrans;
VendInvoiceTrans VendInvoiceTrans;
VendInvoicePurchLink VendInvoicePurchLink;
VendInvoiceJour VendInvoiceJour;
VendTransOpen VendTransOpen;
VendSettlement VendSettlement;
InventBatch InventBatch;
InventDim InventDim;
InventSum InventSum;
MarkupTrans MarkupTrans;
LedgerBalancesTrans LedgerBalancesTrans;
LedgerBalancesDimTrans LedgerBalancesDimTrans;
str id;
ttsbegin;
delete_from PurchLine where PurchLine.PurchId=='123456789';
delete_from PurchTable where PurchTable.PurchId=='123456789';
delete_from VendInvoiceTrans where VendInvoiceTrans.PurchId=='123456789';
delete_from VendInvoicePurchLink where VendInvoicePurchLink.PurchId=='123456789';
delete_from VendInvoiceJour where VendInvoiceJour.PurchId=='123456789';
delete_from InventBatch where InventBatch.InventBatchId=='123456789';
while select InventDim where InventDim.InventBatchId=='123456789'
delete_from InventSum where InventSum.InventDimId==InventDim.InventDimId;
delete_from InventDim where InventDim.InventBatchId=='123456789';
while select InventTrans where InventTrans.TransRefId=='123456789'
if (InventTrans)
v=InventTrans.Voucher;
delete_from MarkupTrans where MarkupTrans.Voucher==v;
delete_from TaxTrans where TaxTrans.Voucher==v;
while select VendTrans where VendTrans.Voucher==v
delete_from VendTransOpen where VendTransOpen.RefRecId==VendTrans.RecId;
//while select VendTrans where VendTrans.Voucher==v
// delete_from VendSettlement where VendSettlement.TransRecId==VendTrans.RecId;
delete_from LedgerTrans where LedgerTrans.Voucher==VendSettlement.TaxVoucher_RU;
delete_from VendSettlement where VendSettlement.OffsetRecId==VendTrans.OffsetRecId && VendSettlement.TransRecId==VendTrans.RecId;
delete_from VendTrans where VendTrans.Voucher==v;
while select LedgerTrans where LedgerTrans.Voucher==v
delete_from LedgerBalancesTrans
where LedgerBalancesTrans.TransDate==LedgerTrans.Transdate && LedgerBalancesTrans.AccountNum==LedgerTrans.AccountNum && LedgerBalancesTrans.DebitMST == LedgerTrans.AmountMST;
delete_from LedgerBalancesDimTrans
where LedgerBalancesDimTrans.TransDate==LedgerTrans.Transdate && LedgerBalancesDimTrans.AccountNum==LedgerTrans.AccountNum && LedgerBalancesDimTrans.DebitMST == LedgerTrans.AmountMST;
delete_from LedgerTrans where LedgerTrans.Voucher==v;
delete_from InventTrans where InventTrans.TransRefId=='123456789';
ttscommit;
Старый 21.12.2005, 18:22   #2
slava09 is offline
slava09
Аватар для slava09
Дети Юза
1,642 / 237 (11) ++++++
C 2.5 не знаком поэтому спорить не буду.
В 3 можно втупую прибить разнесенный заказ или сделать это процедурой соответствующей.
Насчет 1С - не дешевый это способ контачить 1С и Аксапту. И очень даже хлопотный, насколько я понимаю. Но гораздо более приемлемый чем делать из Аксапты 1С.
KMActionPlanTable -удалить таблицу из запроса kitty DAX: Программирование 1 20.11.2007 10:37
Как через .NET коннектор удалить записи? Jab Straight DAX: Программирование 6 09.11.2007 18:56
Как удалить Производственный Заказ Nic DAX: Функционал 15 03.08.2005 09:39
Как создать закупку из кодов? somebody DAX: Программирование 4 15.10.2003 11:34
Функция "Удалить строки" Oks DAX: Функционал 1 03.07.2002 18:09
Часовой пояс GMT +3, время: 21:00.
