Старый 02.07.2012, 17:40   #1
25,644 / 848 (80) +++++++
Connector for Microsoft Dynamics V2 Rollup 1 was released on Friday! This release includes enhanced integration options and maps, and also resolves some of the key issues that you might be facing with your V2 deployments. Additional features and updates are listed later in this post.
Stay tuned to the Connector blog for upcoming videos that detail the new features and functionality.
To download this release for Microsoft Dynamics NAV, go to PartnerSource:
Don’t have access to PartnerSource but would like to know more? Check out the User Guide for NAV and begin your installation preparation.
Here is an overview of the feature list:
  • Features across ERP products:
    • Microsoft Dynamics CRM Duplicate detection rules are now supported on child entities as well as on parent entities, reducing the likelihood of duplicate records getting into your system.
    • On-demand workflows for account and contact are now installed in Microsoft Dynamics CRM 2011 that allow you to “Bulk submit” these entities and streamline the process for creating new accounts and contacts.
    • The Microsoft Dynamics CRM 2011 Configuration utility no longer overwrites your custom changes to object provider configuration files, so you don’t have preserve a separate copy when re-running the Configuration utility.
    • If attributes are deleted in Microsoft Dynamics CRM 2011, then re-running the Microsoft Dynamics CRM 2011 Configuration utility removes them from the object provider configuration file for that entity. You no longer have to do this manually.
    • Microsoft Dynamics CRM 2011 entities that appear in the log not only have their unique key listed in the “Key” column but also have the value of their primary attribute listed. This allows for easier troubleshooting of integration errors within Microsoft Dynamics CRM 2011.
    • A help file has been added to the function selection page that explains all of the functions in our default library, so you can easily search for the function that you may need for customization.
    • Documentation has been updated to include more detail on how each map functions and the assumptions that they make about your data, which improves your upfront costing when evaluating Connector for Microsoft Dynamics.
    • Primary contacts that are associated to accounts in Microsoft Dynamics CRM 2011 are now checked to see if they have been previously submitted when the account is submitted, so you will no longer receive an error in Connector for Microsoft Dynamics when this situation occurs.
    • Parent accounts that are associated to contacts in Microsoft Dynamics CRM 2011 are now checked to see if they have been previously submitted when the contact is submitted, so you will no longer receive an error in Connector for Microsoft Dynamics when this situation occurs.
    • Custom entity references have their “Integration Key” attribute set up when they are retrieved from Microsoft Dynamics CRM 2011, so if your customization needs to get data in or out of this field they can do so.
    • GetCurrencyName() and GetCurrencySymbol() functions are updated to not return blank if the ISO code that is supplied is invalid or out of date. This reduces errors during the integration of currencies.
    • Local machine accounts are now supported for running the Connector for Microsoft Dynamics service, thus removing the dependency on Active Directory for the service account.
    • Connector for Microsoft Dynamics client start time has been improved so the log no longer needs to be cleaned up manually in order to speed up client load time.
    • The Microsoft Dynamics CRM 2011 Configuration utility now uses the integration specific settings for the Microsoft Dynamics CRM 2011 adapter. This allows you to launch the Microsoft Dynamics CRM 2011 Configuration utility directly from the integration settings and not have to re-enter the settings for your integration.
  • Features for Microsoft Dynamics NAV:
    • Mapped fields in Microsoft Dynamics CRM 2011 have the same length as they do in Microsoft Dynamics NAV, preventing data input errors that cause integration failures.
    • After applying the Microsoft Dynamics NAV hotfix found in this KB 2721512 (http://support.microsoft.com/kb/2721512), country/region codes from Microsoft Dynamics NAV are integrated into a global option set in Microsoft Dynamics CRM 2011. Country/region codes that are supplied by users are validated against this list, preventing invalid data from being entered in Microsoft Dynamics CRM 2011.
    • Microsoft Dynamics CRM 2011 account numbers can no longer be updated after the account has been submitted, eliminating potential integration errors when users inadvertently change an account number in Microsoft Dynamics CRM 2011.
    • “Blocked” customers and items in Microsoft Dynamics NAV are set to an inactive state and status in Microsoft Dynamics CRM 2011, which helps to prevent them from being added to a sales order.
    • Address types are defaulted and not editable in Microsoft Dynamics CRM 2011, which prevents data input errors.
    • Fields in Microsoft Dynamics CRM 2011 that have no corresponding field in Microsoft Dynamics NAV are set to be read-only in Microsoft Dynamics CRM 2011, which helps to prevent data input errors
    • Posted Sales orders that are integrated from Microsoft Dynamics NAV into Microsoft Dynamics CRM 2011 have their status set to “Billed” to allow you to more easily distinguish open invoices from posted ones in Microsoft Dynamics CRM.
Источник: http://feedproxy.google.com/~r/Micro...sed-today.aspx
Часовой пояс GMT +3, время: 15:37.
