Старый 12.05.2016, 20:14   #1
organicax: Movement by template – create movement
Источник: https://organicax.com/2016/05/11/mov...eate-movement/
In a previous post we had a look at the movement by template menu. There is an parameter that you can look at called create movement. With this option the movement isn’t executed immediately and work will be created for someone else to go an execute later. This is useful for example if you have someone adjusting bins or locations and they can walk around and create suggested moves. Someone or a group of people would go and execute the work later.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Warehouse management
organicax: Assigning a WMS work template to a disposition code Blog bot DAX Blogs 0 10.05.2016 10:11
Van Vugt: How-to: Create a Workflow Template Blog bot Dynamics CRM: Blogs 0 27.12.2015 17:00
axaptapedia: Create New AOT Project From Template Blog bot DAX Blogs 0 29.08.2008 21:10
Часовой пояс GMT +3, время: 19:42.
