Старый 09.06.2016, 17:11   #1
25,644 / 848 (80) +++++++
stoneridgesoftware: Mass Closing of Financial Periods Included in Dynamics AX 2012 R3
Источник: https://stoneridgesoftware.com/mass-...cs-ax-2012-r3/
I recently was at the point in a client’s implementation where we were discussing the month-end processes. When we got to the part about closing the financial periods (or putting them on hold), I had to explain that Dynamics AX didn’t have an easy way of handling this, but that some clients export the data from the Fiscal period tables into Excel using either the Dynamics Excel Add-in or Atlas and change and update the statuses using that method.
When I did a web search to see what others were reporting on, imagine my surprise to find out that Microsoft had recently released new functionality for Dynamics AX 2012 R3 to do mass closing of financial periods. The short description of the functionality is that it allows you to mass close periods across legal entities from a single screen. The more detailed description, including screenshots, can be found at this mass financial period close Microsoft blog. The KB number on this is KB3146578, and it appears to only be available for AX 2012 R3. I can’t predict whether Microsoft will backport this to their other AX platforms, but for those of you on R3, this should prove to be a timesaver.
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 17:20.
