Старый 12.07.2016, 01:17   #1
25,644 / 848 (80) +++++++
Channel9 CRM: Demo - How to use Machine Learning on sales pipeline
Источник: https://channel9.msdn.com/blogs/Mach...sales-pipeline
Steps to install
  • Download zip file
  • Extract content
  • Double click on exe - CRMInstaller.exe
  • Provide CRM Credentials
  • Provide Azure credentials
Installer will deploy e2e solution in your Azure subscription. It takes 8 minute to deploy. Installation is 1 time activity.
How to see results
To use opportunity score go to Dynamics CRM and load opportunity entity form.
  1. Open an opportunity.
  2. On this form you will see a score field. Score field is coming from Machine Learning model. Score tells likelihood of winning an opportunity
  3. Click on score field. You will see explanation and insight why a given opportunity has this score. It will provide insight what should be done to improve the score.
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
Channel9 CRM: Building a CRM 2011 Virtual Machine Blog bot Dynamics CRM: Blogs 0 26.01.2011 18:11
Часовой пояс GMT +3, время: 14:45.
