Старый 01.09.2016, 01:18   #1
25,644 / 848 (80) +++++++
organicax: WMS Mobile device menu – License plate break
Источник: https://organicax.com/2016/08/31/wms...e-plate-break/
In a previous post we had a look at building a parent license plate with the license plate build menu. If you need to split a license from a parent then you can use the license plate break menu.
Here is a quick overview.
AX2012 R3 CU10
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS Mobile device menu – Start production order Blog bot DAX Blogs 0 01.09.2016 01:18
organicax: WMS Mobile device menu – display open work list user directed menus Blog bot DAX Blogs 0 07.08.2016 01:16
organicax: WMS Mobile device menu – Override target license plate Blog bot DAX Blogs 0 06.08.2016 03:27
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Часовой пояс GMT +3, время: 03:42.
