Старый 28.09.2016, 22:15   #1
organicax: MES terminal setup in AX7
Источник: https://organicax.com/2016/09/28/mes...-setup-in-ax7/
If you are looking to configure the manufacturing execution system in AX7 there are a good amount of parameters that you will need to work through to make your processes. For the terminal configuration you have parameters to control how the terminal form behaves, what is displayed in of the menus and the grid layouts.
Here is a quick overview to give you a view of where to find the setup. I don’t got through the effect of each parameter in this video just a navigation.
AX7 Build 7.0.4230.16130
If you are looking at moving to AX7 from AX2012 you will see in the video a few differences to the setup.
Cheers
Lachlan
Filed under: Production control
organicax: Enabling an employee for MES, Shop Floor in AX7 Blog bot DAX Blogs 0 28.09.2016 22:15
organicax: MES terminal – touch screen Blog bot DAX Blogs 0 28.09.2016 09:11
organicax: MES terminal setup – barcode scanner Blog bot DAX Blogs 0 28.09.2016 09:11
organicax: WMS Packing compile of setup posts. Blog bot DAX Blogs 0 26.07.2016 16:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
Часовой пояс GMT +3, время: 20:58.
