Старый 06.10.2016, 20:13   #1
organicax: Inventory by item group aging AX7
Источник: https://organicax.com/2016/10/06/inv...oup-aging-ax7/
In an earlier post we had a look at the inventory by item group aging report in AX2012. If you are working with AX7 then the report is available as well to use for your on-hand inventory analysis.
Here is a quick overview.
AX7 Build 7.0.4230.16130
Cheers
Lachlan
Filed under: Supply chain planning
organicax: Inventory by item group aging report Blog bot DAX Blogs 0 04.10.2016 12:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Часовой пояс GMT +3, время: 14:11.
