#1 |
waldo: How I upgraded to Microsoft Dynamics NAV 2017
Источник: https://dynamicsuser.net/nav/b/waldo...amics-nav-2017
============== ![]() We recently upgraded successfully our product to NAV2017. In fact, one day after the actual availability of the Belgian download, we had our upgraded product ready. As promised, here is a short post about the challenges we faced during the upgrade. Probably not all challenges are represented here .. and I might have had issues that you won’t have :-). Keep that in mind. The Scope First step for me always is an “upgrade” in the pure sense of the word. No redesign, no refactoring, no new features. Just the customized code transferred to the new version of NAV. That’s what this post is about. Next step (and release) for us is going to be incorporating the new features that Microsoft brings us. Just to give you a feeling: this product of ours is quite big:
How I did my upgrade I upgraded our product in these steps:
Again, this doesn’t involve any significant code re-design to fit the new features. That’s what we will be doing from now on. ![]() So, let’s dive into the things that are worth mentioning (in my book (no, I’m not writing a book …)). Refactored objects During solving the conflicts, you run into objects that are quite refactored by Microsoft. I assume to know why they are doing this. Part of the reason must be facilitating more events. This needs to be done in refactored code .. . So let’s be clear: I totally support the fact that Microsoft is redesigning the code .. It’s a step we must take, although it doesn’t make the upgrade-life much easier.. . These are a few points that I was struggling with.. : COD414 and COD415 Release Sales/Purchase Document OnRun moved to “Code” trigger. For the rest quite the same – so merging is quite fine .. . Though, I would have expected a bigger change. While you’re already changing the main trigger that will cause a conflict anyway – why not just refactor the whole thing. This is not really refactoring, this is moving and causing a conflict without any benefit… COD448 – Job Queue Dispatcher The Job Queue has totally changed. This is not a surprise, as it is running on a completely different platform, with a completely different concept, having multiple threads (workers?) waiting for the scheduler to drop something on its queue.. . I decided to ignore all my changes to the job queue, and start fresh. This will be something to look at after the upgrade. COD5982 – Service-Post+Print Microsoft removed a function “PrintReport” and put it on record-level, which means in this case: 4 places. I had one hook in this function .. and now it had to be placed on 4 places.. . This is the only place where “hooks” didn’t really serve me well as I don’t want to place one hook function in four places.. . The redesign does make sense, though, so I’m not complaining. I created new hooks, and off we go :-). COD82 – Sales-Post + Print Similar changes (I like the consistency). Again, the PrintReport was moved to rec-level, which didn’t make my hook-moving going swell.. but I survived :-). COD80: Must be the most refactored codeunit together with COD90. the code seems to still be all there in CU80, only in (local) functions. So this was really just a matter of moving my hooks to the right local function. You could see that the code structure was still quite the same, so it wasn’t that difficult to find out where the hook had to go.. . A few other things caught my mind though, that wasn’t always that easy ..
TAB37: VAT calculation has moved to VATAmountLine table to “UpdateLines” function. Moving this function means moving your hook to another hook codeunit .. . It does make more sense, but in my book, this is one of the more challenging things to do ;-). ApprovalsMgt Turned into Variant Façade So, code like: ApprovalsMgmt.DeleteApprovalEntry(DATABASE::”Sales Header”,”Document Type”,”No.”); Needs to be changed to: ApprovalsMgmt.DeleteApprovalEntry(SalesHeader); We used this kind of code quite a lot in our product.. . Some work, but the refactoring makes so much sense. Love it! Item Category Default fields moved to “Item Template” .. . This is quite a big change, because we added 6 extra default fields .. and created some functionality on top of this. These default fields being moved to item template, meant we need to rethink our functionality as well .. . This is for after the upgrade, as in my opinion, “rethinking functionality” should not be part of the upgrade. Pages Pages is not easy. This is a refactoring-bit that I don’t like. Microsoft tends to put stuff on pages. Like:
So if you would have changed or deleted any of these fields on pages, you would have conflicts. You get things like this: ![]() In my case: LOADS of them.. . Thing is: also on moved fields you get this :(. I had conflicts on about all fields that we changed – just because of the design of these new features (page-field-level…). This was just one example. Other very recurring conflicts were:
![]() A few numbers:
Deleted objects In my case (BE upgrade from 2016 CU9 to 2017), a total of 96 objects were deleted. The chance you have references, table relations or whatever to any of these objects is quite big. This is something that you’ll need to handle after the upgrade while compiling your code. Very dependent of what and how you’re using these objects. Why there are so many deleted objects. Well .. So much has been refactored .. like: – reworked notifications – reworked CRM wizards – reworked job queue – … In my case, only one conflict here. Namely the “Credit limit check” has seriously changed. It works with Notifications now. We tapped into it, so we needed to revise the complete solution (which ended up in removing it :-)) Irregularities What I was really surprised about is some irregularities in the code of Microsoft. Sometimes, this was really confusing. One example that comes to mind is the variable “RowIsNotText” in page 46. This variable is used to handle the “Enabled” and “Editable” property of some fields. You would expect this variable to exist in all similar “subforms”. Well – no. In fact, in all other subforms, there was the similar but completely opposite variable “RowIsText”. Be careful for this! Upgrade Toolkit Once I had compiled objects (all merged, imported and compilation errors solved), I started to work on my data upgrade. Of course I used the upgrade toolkit that comes with the product. I had two issues in this. The upgrade Toolkit contains errors in function: UpdateItemCategoryPostingGroups. It seems that a temp table in combination with an AutoIncrement doesn’t go well together. When you have multiple Item Categories, it failed on this function from the second entry .. . I did a dirty fix on this, doing this (just making sure the table is empty, so that the OnInsert code is being able to run. ![]() Another issue was that Microsoft didn’t do a “INSERT(TRUE)” for the UpdateSMTPMailSetupEncryptPassword. The OnInsert needs to run, but Microsoft had put just “INSERT”, not “INSERT(TRUE”, which seemed like a bug (no GUID was created). We changed it to INSERT(TRUE). ![]() Solving conflicts with VSCode Just for the sake to get myself familiar with VSCode, I decided to handle conflicts in this editor. Sure, it’s not code, it’s just TXT files .. but why not :-). It is a code editor .. and text file or not – I’m editing code. Here is how it looked like: ![]() A few things that I really liked about this approach.
Conclusion I was happy to be able to have an upgrade in only 12 hours. Taking into account that so much was refactored, plus the most conflicts I had to solve in over 3 years .. it was still “just” 12 hours. Still, it’s 4 times the time that I spent in my previous upgrade .. . I hope this doesn’t mean that someone who did 1 month last time, will spend 4 months ;-). Microsoft has given us the tools to do this as efficient as possible. Yes, I’m talking about PowerShell. My scripts on top of these building blocks has helped me tremendously again .. I can only recommend them for you. “Hooks” helped me a lot again this time as well. Putting them into the refactored code was quite easy. I spent more time on some pages then I did on Codeunit 80. So .. good luck, hope this helps you a bit. Источник: https://dynamicsuser.net/nav/b/waldo...amics-nav-2017
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
