Старый 03.01.2017, 22:12   #1
emeadaxsupport: Inventory value report doesn’t show some inventory dimensions.
Источник: https://blogs.msdn.microsoft.com/axs...ry-dimensions/
Normally, we use inventory value report to view the inventory value and quantity. Sometimes, we cannot see some inventory dimensions in the report. To make the inventory dimensions showing in the report, you need to make sure: 1) Go to USMF/Inventory management/Setup/Inventory/Inventory value reports, select the inventory value report ID which you use to view... Read more
emeadaxsupport: View a full breakdown of cost per item using the Inventory Value Statement with Standard Cost Breakdowns report in Dynamics AX Blog bot DAX Blogs 0 01.05.2015 01:12
dax-lessons: How to display/show the inventory dimensions as parameters on SSRS reports [Dynamics AX 2012, X++] Blog bot DAX Blogs 0 01.08.2013 00:12
emeadaxsupport: AX 2009: The “Goal” value in the Profitability Analysis report on RoleCenter page pages does not show the budgeted values Blog bot DAX Blogs 0 05.04.2012 14:11
Часовой пояс GMT +3, время: 18:59.
