Старый 01.02.2017, 05:22   #1
organicax: Setting up budget control parameters in project accounting
Источник: https://organicax.com/2017/01/31/set...ct-accounting/
If you are working with projects you might want to enable project budget control to control costs on projects. This will allow you to have a warning or stop costs like purchases going through the system. There are a number of parameter options and it’s import to note that the main project accounting parameters are the default at the time the project is created and then you can override the parameters on the project. It’s also important to point out this is a different budget control to the GL based budget control.
Here is a quick overview of some of the parameters.
AX2012 R3 CU11
In a later video we’ll have a look at how some of these behave.
Cheers
Lachlan
Filed under: Project management and accounting
organicax: Project budget balances vs cost control forms Blog bot DAX Blogs 0 01.02.2017 05:22
organicax: Project budget control on a purchase order Blog bot DAX Blogs 0 01.02.2017 05:22
dynamicsax-fico: Budget control for fixed assets – Part 1: AX2012 Blog bot DAX Blogs 0 16.04.2016 20:16
emeadaxsupport: How General Budget Reservations will update Committed Cost on Project Contracts Blog bot DAX Blogs 0 21.05.2015 21:12
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Часовой пояс GMT +3, время: 18:47.
