Старый 04.04.2017, 22:11   #1
emeadaxsupport: D365 for Operation CSS Global support incident closure procedure for support incidents involving a bug
Источник: https://blogs.msdn.microsoft.com/axs...volving-a-bug/
Process: Support incidents will be archived for D365 for Operations incidents involving a bug at the time bug information is available in Lifecycle Services (LCS) Example: D365 for Operations support incident created Support incident is researched and found a code change is required by Microsoft Bug for a hotfix request is created Bug is triaged and... Read more
emeadaxsupport: CSS Global support incident closure procedure for AX2012 cases involving external hotfix release Blog bot DAX Blogs 0 20.09.2016 03:29
waldo: NAV 2016: All Published Events Blog bot NAV: Blogs 0 30.05.2016 15:11
emeadaxsupport: Cloud-powered support – logging support incident for AX 2012 Blog bot DAX Blogs 0 28.04.2016 19:13
emeadaxsupport: Protected: Cloud-powered support – logging support incident for AX 2012 Blog bot DAX Blogs 0 26.04.2016 10:11
emeadaxsupport: AX Content: Cloud powered support Blog bot DAX Blogs 0 10.06.2014 00:14
Часовой пояс GMT +3, время: 00:40.
