Старый 23.06.2017, 14:11   #1
25,644 / 848 (80) +++++++
Sumit Potbhare: ePOS | AX 2012 R3 | Declare starting amount using multiple currency
Источник: https://sumitnarayanpotbhare.wordpre...iple-currency/
Hi Guys, Hope you are keeping up with RetailDAXing. In last few weeks I got many questions on “how to declare start amount in multiple currency“. Although this is not something which is provided out of box at POS, but I will show you how to achieve this with minor customization.
NOTE: We will only go through the functional side of this enhancement. You need to discuss this with your DEV team for Customization.
What is “Declare start amount” operation?
Declare the amount that is in the cash drawer when the day or shift starts. This is the amount that Manager provides to Cashier to keep in the drawer, so that Cashier can use it during Change back. Some stores that accepts multiple currency provides the change back in local currency only so they usually perform “Declare start amount” in single currency. But those stores that do provide change back in another currency requires to have another currency change in their drawers.
Assumption
Let us assume an example where the store is dealing with USD and GBP for Change back. We will use the HOUSTON Store in the demo data (AX 2012 R3 CU12) having USD as the local currency.
Design
In the Declare starting amount screen at POS, add radio buttons to select the currency which will be used to declare start amount. Here you will need to do Customization to add the radio button for each currency.
Data changes @ Table level
When you perform Declare starting amount at POS, it creates record in two tables, RetailTransactionTable and RetailTransactionPaymentTrans. So when you perform the operation with other currency (other than setup in the Store form), then you will have to Customize to update the Currency field to GBP (as we have taken other currency in our case) in both the tables.
Now when you perform Close shift, it will automatically calculate (no customization required) the individual currency and create individual record for each currency in Shifts form.
In this illustration we have considered 2 currency, you can use as many as want for which you can maintain a separate master or use the Currency payment method master attached to each Store Payment method.
Feel free to reach out for any clarifications. If you like my blog posts then comment and subscribe to the blogs.
Please follow me on Facebook | Google+ | Twitter | Skype (sumit0417)
Enjoy RetailDAXing.
Disclaimer: The information in the weblog is provided “AS IS”; with no warranties, and confers no rights. All blog entries and editorial comments are the opinions of the author.
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2012 R3 RTM Warehouse Management: How to prevent the creation of two inventDim records considered identical in Dynamics AX 2012 R3 RTM Blog bot DAX Blogs 0 22.12.2014 19:12
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required (Part 4 of 7) Blog bot DAX Blogs 0 07.01.2012 03:18
Часовой пояс GMT +3, время: 11:20.
