Старый 10.08.2017, 00:17   #1
organicax: Building a measure to publish to the entity store – Part 1
Источник: https://organicax.com/2017/08/09/bui...-store-part-1/
Dynamics 365 for Finance and Operations ships with a good collection of report models for Power BI. But there are some areas of the application not covered or you might want to include custom tables or other data into your environment so users can report on the data. You can do this with an aggregate measurement. This is a new object type that allows you to pull your measures and dimensions together for analytics. The measure can then be used to published the aggregate data to the entity store. I did an overview of this process for a customer and I thought I’d publish it as a series of posts so others could learn as well.
This is the first post that walks through the end to end of creating an aggregate measurement. However to add context to the measure and keep the data model simple I created some new tables that will contain our data. This part creates the first of two tables that we’ll use to store our data. In this example it will be a simple table to represent some master data that we can use as a dimension to analyze the transactional data.
D365 July 2017 Update 8 (7.0.4565.16211)
Cheers
Lachlan
Filed under: Business intelligence
stoneridgesoftware: Part I: Configuring the Dynamics AX 2012 R3 Entity Store Blog bot DAX Blogs 0 27.04.2017 12:11
organicax: Working around the modifiedBy error when publishing an entity to the entity store Blog bot DAX Blogs 0 21.02.2017 09:11
organicax: Setting up an entity store in AX2012 R3 CU11 Blog bot DAX Blogs 0 21.02.2017 09:11
organicax: Entity Store AX2012 R3 CU11 Blog bot DAX Blogs 0 29.10.2016 03:41
dynamics-coe: Microsoft Dynamics AX 2012 Reporting Services - Issue deploying OLAP SSRS reports on SharePoint 2013 Blog bot DAX Blogs 0 25.01.2015 12:17
Часовой пояс GMT +3, время: 01:41.
