		#1 |
			shashidotnet: SystemSequences Update
			Источник: https://shashidotnet.wordpress.com/2...uences-update/
			============== If you ever get a error where the RecId being inserted into the table already exists then the SystemSequences table is to be blamed for this In some of my previous blog posts, i update the system sequence table’s NextVal record, which determines the RecId to be given. However, this is tricky.
 static void sab_recIdSequenceFix(Args _args){ SystemSequence systemSequence = new systemSequence(); Tableid tableId = 123456; // use the table id or tablenum() here systemSequence.suspendRecIds(tableId); systemSequence.suspendTransIds(tableId); systemSequence.flushValues(tableId); systemSequence.removeRecIdSuspension(tableId); systemSequence.removeTransIdSuspension(tableId);} Filed under: Ax 2009, Ax 2012, Dynamics Ax, X++ Tagged: Ax 2009, AX2012, Dynamics Ax, x++ Источник: https://shashidotnet.wordpress.com/2...uences-update/
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
