Старый 25.01.2018, 11:11   #1
alirazazaidi: Process Busy Indicator D365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/pr...nd-operations/
Hi All, today I have small tip, During development, I have to process a lot of records. During this , I need Busy screen process indicator.
I used following code snippet to create progress busy indicator.
For this I have to do following changes in my Class method (Business logic).
  1. Convert required method to Static
  2. Parameter is changed to Container and then required parameter extract from container inside the method.
So my required method become something like
Class myProcess{  Public static void RunmyProcess(Container _C){Str _Value = conpeek(_C,1);   } }   class RunBtnProcess{/// ////// public void clicked(){ container _Xyz=[TableName.FieldValue];super();SysOperationSandbox::callStaticMethod(classNum(myProcess),staticMethodStr(myProcess,RunmyProcess),_Xyz, 'Ledger Record in process', 'Operation completed');  } }
Reference : Internet.
alirazazaidi: Parent child form Customization D365 for Finance and Operations Blog bot DAX Blogs 0 21.01.2018 16:14
alirazazaidi: How to apply application hot fix on Dynamics 365 for finance and operations Blog bot DAX Blogs 0 19.01.2018 12:11
alirazazaidi: Customer in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 15.10.2017 20:15
alirazazaidi: Customer Credit limit in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 22.09.2017 21:13
Microsoft Dynamics CRM Team Blog: Using the Business Process Flow Designer Blog bot Dynamics CRM: Blogs 0 24.10.2013 05:13
Часовой пояс GMT +3, время: 20:02.
