Старый 02.02.2018, 04:34   #1
crmtipoftheday: Tip #1066: Discover Azure AD tenant ID with Occam’s razor
Источник: https://crmtipoftheday.com/1066/disc...-occams-razor/
As developers, from time to time we are puzzled by simple questions:
How to discover Azure AD tenant ID based on Dynamics 365 organization URL?
Under the normal circumstances I would have put my condescending hat on (did I forget to take it off, again?) and say something like “Use AuthenticationParameters.CreateFromResourceUrlAsync method from ADAL, of course”. Except that in this instance the question was from the PHP developer working on a new version of php-crm-toolkit.
After asking some people, poking around with the irreplaceable Postman, and toying with the discovery API, etc, I’ve decided to adopt Occam’s razor approach.
Send this to the server:
GET /api/data/v9.0/ HTTP/1.1
Host: foobar.crm.dynamics.com
Get a 401 reply with this header:
WWW-Authenticate Bearer authorization_uri=https://login.windows.net/ede123e5-dead-beef-dead-7ee8d5807f08/oauth2/authorize, resource_id=https://foobar.crm.dynamics.com/
The header contains all that you need to perform the authentication dance. Incidentally, according to David “Xrm.Tools” Yack, this approach is exactly how AuthenticationParameters.CreateFromResourceUrlAsync does the discovery under the hood.
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
organicax: Azure access control features moving to Azure AD Blog bot DAX Blogs 0 19.04.2017 03:19
Часовой пояс GMT +3, время: 19:31.
