Старый 06.02.2018, 23:11   #1
25,644 / 848 (80) +++++++
Why your method is still not running in CIL
Источник: http://alexvoy.blogspot.com/2018/02/...unning-in.html
Please do not forget about the third parameter when you call your CIL wrapper.
It won't run in CIL if the current transaction level is not equal to zero, like in the following example with the standard import of Zip codes.
However, you can try to force ignoring TTS level at your own risk.
It works perfectly for my scenario.
This is how to check if your code is running in CIL.
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
Navigate Into Success: Try..Catch for .NET Interoperability Blog bot Dynamics CRM: Blogs 0 29.10.2014 09:00
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 14:12.
