Старый 02.04.2018, 04:16   #1
crmtipoftheday: Tip #1095: Add percentage labels to pie charts
Источник: https://crmtipoftheday.com/1095/add-...to-pie-charts/
Welcome to chart week! This week on CRM Tip of the Day, Ulrik “CRM Chart Guy” Carlsson brings us a chart tip every day.
When you create a pie chart on the est. revenue on opportunities broken down by account, or any other currency field, the pie chart automatically displays the value of the slice in the label.
Sometimes, showing the percentage instead of the actual value can be useful. Especially as the pie chart is really intended to show the relative proportions of the individual groups.
Luckily it is very easy to change the labels from the long, two decimal values to a percentage value.
Open the XrmToolBox and open the Advanced Chart Editor. If you don’t have it, you can find it in the plugins store.
  1. Load the entities
  2. Select the opportunity entity to retrieve the charts. Or whatever entity the pie chart you are changing is on.
  3. Select the chart by clicking on the name so it is highlighted in blue.
  4. Then click on Edit Chart.
Click on Open Visual Editor.
Navigate to the series node and change the following values.
  • Font Type to Verdana
  • Font Size to 20
  • IsValueShownAsLabel to False
  • Label #PERCENT
Don’t forget to click Save, then click Ok, to get back to the standard editor.
Click Update
Your updates to the chart XML will now be updated directly in Dynamics 365 without needing the export/import of the XML file.
In Dynamics 365, open view and chart, or if already open, simply refresh the grid to see the updates.
crmtipoftheday: Tip #1076: Add all assets to your solution Blog bot Dynamics CRM: Blogs 0 15.02.2018 09:11
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
NAV Team: Using Client Extensibility in NAV 2009 SP1 to create Charts Blog bot Dynamics CRM: Blogs 0 04.02.2010 01:17
Часовой пояс GMT +3, время: 04:25.
