Старый 26.04.2018, 16:11   #1
goshoom: XML response from OData services
Источник: http://dev.goshoom.net/en/2018/04/xm...data-services/
If you call OData services in AX 7 (Dynamics 365 for Finance and Operations), you typically get data in JSON format, like this:
{ "@odata.context":"https://myaxinstance.cloudax.dynamics.com/data/$metadata","value":[ { "name":"ElectronicPaymentTypes","kind":"EntitySet","url":"ElectronicPaymentTypes" },{ "name":"ExpensePaymentDetails","kind":"EntitySet","url":"ExpensePaymentDetails" } ... ]}
JSON is a simple, lightweight format with good support in many tools, but sometimes you would rather get XML. XML is by no mean deprecated – it’s more than a format; you get a whole platform with capabilities useful for validations (XML schema), querying (XPath, XQuery), transformations (XSLT) and so on. Or you simply have a component that accepts only XML and not JSON.
Fortunately OData services aren’t limited to JSON; they can return XML as well. Simply add HTTP header Accept with value application/atom+xml,application/atomsvc+xml,application/xml and you’ll start getting the same data in XML format:
</span> </span> </span>ElectronicPaymentTypes</span> </span>ElectronicPaymentTypes</span> </span> </span> </span>ExpensePaymentDetails</span> </span>ExpensePaymentDetails</span> </span></span> ... </span></span>
If you use Postman, for example, this is where you can put the header:
Of course, that you get XML format doesn’t mean that you get the structure you want. You still may need to transform it to something more suitable for your purposes.
За это сообщение автора поблагодарили: gl00mie (2).
Freddys: Connecting to NAV Web Services from the Cloud–Part 1 out of 5 Blog bot Dynamics CRM: Blogs 0 01.12.2010 10:59
Freddys: Connecting to NAV Web Services from Windows Mobile 6.5 Blog bot Dynamics CRM: Blogs 0 25.01.2010 10:49
Freddys: Connecting to NAV Web Services from Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 22.01.2010 08:57
Freddys: Connecting to NAV Web Services from Visual Basic .net using Service Reference Blog bot Dynamics CRM: Blogs 0 20.01.2010 20:51
Freddys: Handling Sales Orders from Page based Web Services – in NAV 2009SP1 (and RTM) Blog bot Dynamics CRM: Blogs 0 29.05.2009 00:06
Часовой пояс GMT +3, время: 15:02.
