#1 |
powerobjects: Dynamics 365 Spring 2018 Update: Common Data Service
Источник: https://www.powerobjects.com/2018/05...-data-service/
============== ![]() The Dynamics 365 Spring 2018 release coincides with the new release of Power Apps and the Common Data Service. This release brought about a significant change to the Common Data Service – dividing them into two different areas. Common Data Service for Apps and Common Data Service for Analytics. Our upcoming webinar Spring Release: The Common Data Service and Dynamics 365 will go through all of the changes and enhancements in this new release and how the new Common Data Service for Apps interacts with the Dynamics 365 application platform. In this blog, we will touch on some of the enhancements that will be discussed in the webinar. Be sure to register to learn about all the new features! Integrations – Field Service There is now data integration support between Dynamics 365 Finance and Operations and Dynamics 365 for Field Service. This new functionality includes:
![]() Integrations – Dynamics 365 for Project Service Automation An integration solution using the Common Data Service enables synchronized data between Dynamics 365 Finance and Operations and Dynamics 365 for Project Service Automation. The solution enables the flow of data for several scenarios including the following:
![]() Server-Side Logic for Validation The addition of Business Rules on the Common Data Service for Apps entities now enables you to build business logic for Apps. You can use the Business Rules to:
Happy Dynamics 365’ing! Источник: https://www.powerobjects.com/2018/05...-data-service/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
