Старый 23.08.2018, 21:12   #1
dynamicsaxse: Dynamics AX 2012 R3 Enterprise Portal Setup with Auth0
Источник: https://blogs.technet.microsoft.com/...up-with-auth0/
This article will assist you with the setup of an external Enterprise portal site using Auth0 user authentication mechanism.
Start by downloading the required KB 4133646 for Dynamics AX2012 R3.
Secondly, download the PDF file Dynamics-AX-2012-R3-Enterprise-Portal-Setup-with-Auth0. This document will describe all the steps required to setup your external Enterprise portal site using Auth0.
dynamicsaxse: July 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 25.07.2017 20:11
DAX: A Shift to Effective Demand Forecasting With Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 16.11.2013 02:13
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 09:53.
