#1 |
d365technext: Generate class from SQL database table
Источник: http://d365technext.blogspot.com/201...ase-table.html
============== Generate class from SQL database table declare @TableName sysname = 'BANKACCOUNT' declare @Result varchar(max) = 'public class ' + UPPER(LEFT(@TableName,1))+LOWER(SUBSTRING(@TableName,2,LEN(@TableName))) + 'Entity {' select @Result =@Result + ' public ' + ColumnType + NullableSign + ' ' + ColumnName + ' { get; set; } ' from ( select replace(col.name, ' ', '_') ColumnName, column_id ColumnId, casetyp.name when'bigint' then 'long' when'binary' then 'byte[]' when'bit' then 'bool' when'char' then 'string' when'date' then 'DateTime' when'datetime' then 'DateTime' when'datetime2' then'DateTime' when'datetimeoffset' then'DateTimeOffset' when'decimal' then 'decimal' when'float' then 'float' when'image' then 'byte[]' when'int' then 'int' when'money' then 'decimal' when'nchar' then 'char' when'ntext' then 'string' when'numeric' then 'decimal' when'nvarchar' then 'string' when'real' then 'double' when'smalldatetime' then'DateTime' when'smallint' then 'short' when'smallmoney' then'decimal' when'text' then 'string' when'time' then 'TimeSpan' when'timestamp' then'DateTime' when'tinyint' then 'byte' when'uniqueidentifier' then'Guid' when'varbinary' then'byte[]' when'varchar' then 'string' else'UNKNOWN_' + typ.name endColumnType, case whencol.is_nullable =1 and typ.name in('bigint', 'bit', 'date', 'datetime', 'datetime2', 'datetimeoffset', 'decimal', 'float', 'int', 'money', 'numeric', 'real', 'smalldatetime', 'smallint', 'smallmoney', 'time', 'tinyint', 'uniqueidentifier') then'?' else'' endNullableSign from sys.columns col join sys.types typ on col.system_type_id = typ.system_type_id AND col.user_type_id = typ.user_type_id where object_id= object_id(@TableName) ) t order byColumnId set @Result =@Result +' }' print @Result public class BankaccountEntity { public int ID { get; set; } public string BANK { get; set; } public string ROUNTINGNUM { get; set; } public string CURRENCY { get; set; } public string ACCOUNTNUM { get; set; } public int? MAINACCOUNTID { get; set; } public string IBAN { get; set; } public string SWIFT { get; set; } public string BRANCH { get; set; } public string CONTACTPERSON { get; set; } public string CONTACTPHONE { get; set; } public string CONTACTEMAIL { get; set; } public bool? STATUS { get; set; } } Источник: http://d365technext.blogspot.com/201...ase-table.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
