Старый 31.10.2018, 14:11   #1
crmtipoftheday: Tip #1183: Templates are not working after upgrade
Источник: https://crmtipoftheday.com/1183/temp...after-upgrade/
Release 9.1.X (the coveted October release) is already here and some organizations have already been upgraded to the new version. Steve “Mr SMB” Mordue was, for a change, on the receiving end, as his customers complained that Word templates stopped working after the upgrade. When a template is selected from a record, new shiny Dynamics UI says it is creating, the spinning dialog eventually stops, but then nothing happens and nothing gets created. Steve tried clearing cache, and re-uploading template with a new name, no luck.
Turns out, SharePoint integration was throwing a spanner into the shiny October mag wheels. When downloading your template, make sure the two highlighted SharePoint relationships are not selected.
After that, both Word and Excel templates work like a charm. To the extent they can charm anyone, of course.
The relationships on the screenshot are for the opportunity, you’d want to exclude similar ones when using a different document-enabled entity.
(Facebook and Twitter cover photo by rawpixel on Unsplash)
crmtipoftheday: Tip #1063: Do not touch currency system views Blog bot Dynamics CRM: Blogs 0 29.01.2018 04:21
crmtipoftheday: Tip #1037: Modify data source for Word templates like a boss Blog bot Dynamics CRM: Blogs 0 06.12.2017 09:11
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 18:19.
