Старый 25.11.2018, 08:25   #1
25,644 / 848 (80) +++++++
dynamicsax-fico: Inventory value adjustments (Part 1)
Источник: https://dynamicsax-fico.com/2018/11/...tments-part-1/
In this post, I show you how you can make use of electronic reporting and MS Flow to create automatic inventory value adjustments in MSDyn365FO based on the inventory turn / inventory days of items. The post also shows you how you can deal with exceptions that need to be investigated in more detail by the inventory management.
dynamicsax-fico: Parallel inventory valuation – an alternative approach (Part 5) Blog bot DAX Blogs 0 17.04.2017 10:11
dynamicsax-fico: Parallel inventory valuation – an alternative approach (Part 4) Blog bot DAX Blogs 0 07.04.2017 20:11
dynamicsax-fico: Parallel inventory valuation – an alternative approach (Part 3) Blog bot DAX Blogs 0 29.03.2017 01:16
dynamicsax-fico: Parallel inventory valuation – an alternative approach (Part 2) Blog bot DAX Blogs 0 15.03.2017 18:11
dynamicsax-fico: Parallel inventory valuation – an alternative approach (Part 1) Blog bot DAX Blogs 0 05.03.2017 09:13
Часовой пояс GMT +3, время: 19:20.
