Старый 10.01.2019, 16:12   #1
Denis Trunin's Blogs: How to setup Financial reporting on D365FO local One box VM
Источник: https://denistrunin.com//financial-r...-local-onebox/
Using Financial reporting (aka Management Reporter in Ax2012) on local DEV D365FO one box requires some addition settings, that are not yet documented. This post describes the problem and a possible solution.
Старый 13.01.2019, 20:11   #2
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Спасибо! Терпение и trud все перетруд.
За это сообщение автора поблагодарили: user_ax (2).
emeadaxsupport: Setup for Belgian payment balance Blog bot DAX Blogs 0 22.01.2015 20:12
axmfg: Lean manufacturing: Picking activities and kanban line events Blog bot DAX Blogs 0 26.08.2014 21:13
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Microsoft Dynamics CRM Team Blog: Creating and Publishing a Web Portal to an Azure Cloud Service Blog bot Dynamics CRM: Blogs 0 17.04.2013 23:11
Часовой пояс GMT +3, время: 15:32.
