Старый 15.02.2019, 00:27   #1
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Post D365FO Platform Update 22 (7.0.5095) KB 4486423 bug fixes
Дата выпуска: 23.01.2019 (был еще один выпуск PU22 - KB 4471117 от 20.11.2018, его вскоре после публикации убрали из общего доступа, вернув уже в декабре)
Список исправлений:
  • Issue 255228 Data Integration
    Dual write support for multiple company mapping between CDS and AX
  • Issue 259971 Develop and customize
    Type provider tests may generate unexpected Best Practice (BP) warnings
  • Issue 237566 Develop and customize
    Post-Event handlers on form methods are not triggered in some cases
  • Issue 247968 Intelligence
    Alert framework is not determining field level access rights correctly.
  • Issue 262343 Intelligence
    Dynamics365 On-premises: Something went wrong while generating the report
  • Issue 261104 Intelligence
    SSRS Reports fail to render in development environments.
  • Issue 247205 Localization and Regulatory features
    Wrong date format d.yyyy.MM when strFmt() is used with datetime fields in localization for Slovenia
  • Issue 231449 Localization and Regulatory features
    [Denmark] Danish label for “round-off” is incorrect, should be Afrunding
  • Issue 219120 Organization administration
    Error when creating a new Workflow work uerm queue assigment rule Cannot create a record in Workflow work item queue assignment (WorkflowWorkItemQueueExpressionDef).
    Document: TrvWorkflowExpHeader. The record already exists.
  • Issue 226525 Organization administration
    Unable to select document key in free text invoice sub-workflow
  • Issue 246152 Organization administration
    Workflow execution account setup is not working correctly
  • Issue 180310 Organization administration
    Workflow delegation gives unexpected results
  • Issue 262155 Runtime
    DatabaseSynchronize Event Provider Channel is not deploying
  • Issue 173920 Runtime
    Cannot edit a record in PCLUDFDateTimeValue (PCLUDFDateTimeValue). Data update is not allowed on a field that has not been selected.
  • Issue 262822 Runtime
    Cached table data methods exception handling.
  • Issue 259545 System Administration
    Enable sending AAD invitation email for B2B invitation
  • Issue 256702 Upgrade
    Data Upgrade fails on step 6 due to unrecognized additivetablesync parameter
  • Issue 252748 User Interface
    User sees an “Invalid value (XXXX*) specified in the query predicate” error when changing the filter operator in the Product Reservation hierarchy dropdown
d365 for operations, d365fo
D365FO Platform Update 21 (7.0.5073) KB 4477851 bug fixes gl00mie DAX: Администрирование 1 14.02.2019 23:25
D365FO - Platform update против Platform and application binary package - Что? Где? Когда? MarinaAX DAX: Администрирование 1 06.02.2019 03:19
dynamicsaxse: December Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 04.01.2018 03:46
stoneridgesoftware: Microsoft has Released the 4th Platform Update for Dynamics 365 for Operations Blog bot DAX Blogs 0 12.04.2017 02:30
Часовой пояс GMT +3, время: 00:00.
