Старый 07.03.2019, 19:11   #1
crmtipoftheday: Tip #1228: Control default destination for you Dynamics 365 URL
Источник: https://crmtipoftheday.com/1228/cont...amics-365-url/
In some environments with Dynamics 365 v9, when you go to the URL for your Dynamics 365 URL you get the classic default app, while in others you get the Unified Interface app selector.
To control this behavior, go to the Power Platform Admin Center , select Environments and select the desired environment.
Click the settings gear and select Behavior.
Set Open in classic mode to off if you want the URL to go to the Unified Interface app menu.
Thanks Shidin Kuruvath Haridas for the great tip. Got any tips? Send them to jar@crmtipoftheday.com.
(Cover photo by Matthew Smith on Unsplash)
crmtipoftheday: Tip #1045: Missing fields on Dynamics 365 account form Blog bot Dynamics CRM: Blogs 0 18.12.2017 03:33
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
NAV Team: Validating Single Sign-on with Office 365 and Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:00
Часовой пояс GMT +3, время: 12:52.
