Старый 16.04.2019, 22:12   #1
butenko.pro: Refreshing the ribbon – form vs grid
Источник: https://butenko.pro/2019/04/16/refre...-form-vs-grid/
So today my colleague experienced issue refreshing grid of the grid. According to SDK formContext.ui.refreshRibbon had to to the trick but it did not work. After some digging and googling I found an answer – there is a global function using which it is possible to refresh the grid – refreshRibbon so here is tip ...
butenko.pro: HowTo: Show ribbon button depending on Application running Blog bot Dynamics CRM: Blogs 0 07.01.2019 09:28
butenko.pro: Showing ribbon button based on the result of async operation Blog bot Dynamics CRM: Blogs 0 13.11.2018 10:11
Часовой пояс GMT +3, время: 18:38.
