Старый 04.09.2019, 17:11   #1
crmtipoftheday: Tip #1301: When Dynamics 365 for Marketing segments disagree with Advanced Find
Источник: https://crmtipoftheday.com/1301/when...advanced-find/
Today’s tip is from marketing superstar Allison Fierce. Got any tips? Send them to jar@crmtipoftheday.com.
Are you trying to reference a custom lookupfield on your contact record when building Segments in D365 for Marketing? Areyou not getting any members? It might be because of you haven’t enabled theentity for segments.
Enabling an entity for Segments requires youto set up two components:
  1. Changetracking must be enabled on the entity itself
  2. Youmust check the box for that entity under Customer Insights sync
You can enable change tracking, if it isn’t already on, by going to your preferred solution and making that customization to the entity record:
For our Customer Insights sync, you’ll make the configuration in the D365 for Marketing Settings area. Under the Marketing Settings subgroup, you’ll find the Customer Insights sync configuration for your environment. Only entities that are enabled for this will work with your Segments tool.
To make your custom lookup function with a segment, check the box here and then be sure to click the “Publish” button at the top of the entities list.
It may take up to 30 minutes to see thesystem reflect this change.
Please keep in mind, these settings cannot beturned off once they are enabled. They do affect your system’s performance, sothe best practice is to only enable the entities you need to use with segments.
Once you enable the entity for use in segments, you can choose to build your segment referencing that entity. Below, you can see a segment built to look for Active Contacts whose related user record (our lookup field) equals a specific user.
crmtipoftheday: Tip #1276: Do my Dynamics 365 users need a Microsoft Flow license? Blog bot Dynamics CRM: Blogs 0 21.06.2019 19:12
crmtipoftheday: Tip #1117: Category/delegate tracking in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 23.05.2018 09:12
crmtipoftheday: Tip #1091: Dynamics 365 App for Outlook version 9.0 is now available Blog bot Dynamics CRM: Blogs 0 22.03.2018 22:13
crmtipoftheday: Tip #1051: SharePoint license included in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 08.01.2018 03:49
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
Часовой пояс GMT +3, время: 17:35.
