Старый 28.11.2019, 05:34   #1
Enum extensions case in D365
Источник: http://alexvoy.blogspot.com/2019/11/...e-in-d365.html
Added two new values to an enum in the same model but in two different extensions.
The first one is looped perfectly (see code snippet below), and nothing but an index for the second. However, its value is present in a combobox.
[ExtensionOf(formStr(SysPolicyParameters))]
final public class CDPSysPolicyParametersForm_9180_Extension
public void populateTree()
DictEnum policyRuleTypeEnum;
int i;
policyRuleTypeEnum = new DictEnum(enumNum(SysPolicyRuleTypeEnum));
for(i = 0; i < policyRuleTypeEnum.values(); i++)
str sym = policyRuleTypeEnum.value2Symbol(i);
info(strFmt("%1 %2 %3", i, policyRuleTypeEnum.value2Name(i), sym));
next populateTree();
Already built and syncrhonized the whole world. What else can it be?
Take a look from the SQL side.
There are some old values that I created before but deleted later. All of them are still there.
I had to delete these unsynced values manually from SQL, then added needed values in AOT, and synched DB.
In fact, DB sync is triggered if you have some changes in tables/views only.
Now it is correctly recreated.
BTW there are two good articles about the subject
1) Extensible enums: Breaking change for .NET libraries that you need to be aware of
2) Development tutorial: Extensible base enumerations in Microsoft Dynamics AX 7
How to see enum values in D365 Blog bot DAX Blogs 0 03.05.2019 22:15
D365 не видит extensions UI-элементов fed DAX: Программирование 11 20.07.2018 11:25
Extensions and Edit and Display methods declaration in D365 Blog bot DAX Blogs 0 07.06.2018 03:25
Get Model element type name from its ID Blog bot DAX Blogs 0 14.02.2017 01:13
Leon's CRM Musings: Tracking the Movements of a Case Blog bot Dynamics CRM: Blogs 0 24.07.2015 00:13
Часовой пояс GMT +3, время: 19:56.
