Старый 10.03.2020, 21:15   #1
Alexdmeyer: Best Practice for Moving D365FO Security Between Environments
Источник: https://alexdmeyer.com/2020/03/10/be...-environments/
One of the questions I get quite often is now that I know that security created/modified from the AOT is stored differently than security created/modified from the user interface, what is the best way to move security between environments effectively and ensure the validity of the tested security in each environment? Treat Security as Code […]
The post Best Practice for Moving D365FO Security Between Environments appeared first on Alex Meyer.
Alexdmeyer: Securing the Open in Microsoft Office Button in D365FO Blog bot DAX Blogs 0 02.12.2019 18:11
Alexdmeyer: Gaps in the Security Diagnostics for Task Recordings Feature in D365FO Blog bot DAX Blogs 0 11.11.2019 22:14
Alexdmeyer: Tool To Help Migrate D365FO Security Between Environments Blog bot DAX Blogs 0 25.10.2019 17:12
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 19:57.
