Старый 01.05.2020, 13:11   #1
ariste.info: Azure hosted build for Dynamics 365 Finance & SCM
Источник: https://ariste.info/en/2020/05/azure...5-finance-scm/
Behold #XppGroupies! The day we’ve been waiting for has come! The Azure hosted builds are in public preview with PU35!! We can now stop asking Joris when will this be available, because it already is! Check the docs! I’ve been able to write this because, thanks to Antonio Gilabert, we’ve been testing this at Axazure … Continue reading Azure hosted build for Dynamics 365 Finance & SCM →
La entrada Azure hosted build for Dynamics 365 Finance & SCM se publicó primero en ariste.info.
ariste.info: Unzip a Stream in Dynamics 365 FnO Blog bot DAX Blogs 0 24.03.2020 15:11
ariste.info: Using Azure Application Insights with MSDyn365FO Blog bot DAX Blogs 0 05.04.2019 09:11
powerobjects: Using Azure KeyVault to Encrypt D365 for Finance & Operations Data Blog bot Dynamics CRM: Blogs 0 09.10.2018 02:23
stoneridgesoftware: How to Launch Report Designer in Dynamics 365 for Finance & Operations from Chrome Blog bot DAX Blogs 0 27.04.2018 19:13
stoneridgesoftware: Webinar: When & How to Upgrade from Dynamics AX to Dynamics 365 for Finance & Operations Blog bot DAX Blogs 0 06.04.2018 06:15
Часовой пояс GMT +3, время: 04:43.
