Старый 29.04.2021, 22:13   #1
powerobjects: Azure Data Factory (ADF) V2 – Lookup
Источник: https://powerobjects.com/azure/azure...adf-v2-lookup/
ADF is a data integration service based in the cloud and is a part of Microsoft’s analytics suite. However, ADF Pipeline is used for an Extract Transform Load purpose (Data Integration/Data Migration between two systems – on-prem or cloud – on a bigger scale). A Pipeline is a data-driven workflow where data is orchestrated to transform as per Target system requirements. ADF Pipeline is both...
Source
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
powerobjects: A Day in the Life of a Dynamics 365 Data Expert Blog bot Dynamics CRM: Blogs 0 29.10.2018 22:13
powerobjects: Using Azure KeyVault to Encrypt D365 for Finance & Operations Data Blog bot Dynamics CRM: Blogs 0 09.10.2018 02:23
powerobjects: Data Export Service: How to Handle Lookup Columns Blog bot Dynamics CRM: Blogs 0 23.01.2018 01:17
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 07:50.
