Старый 30.04.2021, 14:13   #1
ax.docentric: Comment on Import/Export Container Data Fields Using D365FO Data Management by Guillaume De Bue
Источник: https://ax.docentric.com/import-expo.../#comment-2479
hi ,I see you are overwritting the postload method on the data entity. Are you still able to skip the staging on the data entity for export?I am just thinking of the performance for the export.Thank you for the documentation!
ax.docentric: Comment on Create a new custom report in D365FO using Docentric by Ana Blog bot DAX Blogs 1 10.11.2020 19:11
ax.docentric: Comment on Create a new custom report in D365FO using Docentric by Ana Blog bot DAX Blogs 0 05.11.2020 03:14
stoneridgesoftware: Automated Data Entity Import Using DIXF in Dynamics AX Blog bot DAX Blogs 0 07.08.2017 20:19
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
dynamics-coe: Dynamics AX Export/Import Framework for Vendor balance migration Blog bot DAX Blogs 0 22.05.2013 20:13
Часовой пояс GMT +3, время: 17:37.
