Старый 09.09.2021, 22:13   #1
d365technext: Interfaces & Abstract Class
Источник: https://d365technext.blogspot.com/20...eAbstract.html
Interfaces VS Abstract Class?
The class implementing is the interface that implements all interface methods and there will not be any abstract Class requirement. There are many access modifiers available like abstract, protected, virtual, internal, public, and many more that are useful in the abstract Classes. Abstract classes will be very fast when compared to interfaces.
Abstract class contains both the incomplete or complete methods and the interface is the signature for a particular method. The abstract class is the implemented method but the interface cannot be an implemented method.
The abstract class contains constructors, fields, or destructors for implementing the properties. The interface does not contain constructors, fields, or destructors but they have only the property’s signature with no implementation.
The abstract class does not support multiple inheritances and the interface supports multiple inheritances. The class can also inherit more interfaces but only a single abstract class.
d365technext: Class Extension D365FO Blog bot DAX Blogs 0 08.08.2018 14:11
d365technext: Private, Protected and Public attribute access in Class Extension Blog bot DAX Blogs 0 30.07.2018 20:13
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
Часовой пояс GMT +3, время: 12:15.
