Старый 09.09.2021, 22:13   #1
d365technext: What are AOS in AX & D365FO
Источник: https://d365technext.blogspot.com/20...AOSD365FO.html
AOS in AX & D365FO
The Microsoft Dynamics AX / D365FO (Finance & Operations) Object Server (AOS) is the second-tier application server in the Microsoft Dynamics AX three-tier architecture.
The AX 2012 3-tier environment is divided as follows:
  • First Tier – Intelligent Client
  • Second Tier – AOS
  • Third Tier – Database Server
In D365FO N-tier environment is divided as follows:
  • X-Tier – AOS, and Batch servers
  • X-Tier – Database Server
In an N-tier solution, the database runs on a server as the X tier; the AOS handles the business logic, Batch jobs/ background process in multiple tiers, and handles the user interface and necessary program logic.
d365technext: Default Dimension D365FO AX-2012 Blog bot DAX Blogs 0 03.09.2018 21:12
d365technext: Record sorting D365FO, AX 7 and AX-2012 Blog bot DAX Blogs 0 08.08.2018 21:12
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Часовой пояс GMT +3, время: 17:56.
