Старый 22.06.2024, 06:42   #1
25,643 / 848 (80) +++++++
Importing a bacpac file to a development box SQL
Источник: http://alexvoy.blogspot.com/2024/06/...velopment.html
Just to memorize some steps to import a database from a bacpac file.
@echo Importing a bacpac data to SQL database c: cd C:\Program Files\Microsoft SQL Server\160\DAC\bin SqlPackage.exe /a:import /sf:G:\backup.bacpac /tsn:localhost /tdn:AxDB_Restored /p:CommandTimeout=1200 /TargetTrustServerCertificate:True pause
Take note about the last option: without it importing fails with the following error.
Navigate Into Success: NAV performance part 4: SQL Azure Blog bot NAV: Blogs 0 15.05.2016 18:12
Navigate Into Success: Deploying control add-ins during development in NAV 2016 Blog bot Dynamics CRM: Blogs 0 13.11.2015 10:00
emeadaxsupport: Importing a General Journal using Data Import/Export Framework AX 2012 Blog bot DAX Blogs 0 17.07.2014 20:12
Часовой пояс GMT +3, время: 05:19.
