Старый 18.07.2024, 21:16   #1
25,643 / 848 (80) +++++++
dynamicsaxinsight: D365: Download multiple files in X++
Источник: https://dynamicsaxinsight.com/2024/0...-files-in-xpp/
Purpose:
Demonstrate how can download multiple files in X++.
Application:
Dynamics 365 for Finance and Operations
Business requirement:
Business requirement is to let users download multiple files using a single browser session.
Solution:
We can use the code below to download multiple files using a single browser session.
Code
class ATLAS_Vend_File_Export{ private void exportFile(TextStreamIo _file, Filename _fileName) { System.IO.StreamReader reader; System.IO.Stream stream; str fileContent; stream = _file.getStream(); stream.Position = 0; reader = new System.IO.StreamReader(stream); fileContent = reader.ReadToEnd(); File::SendStringAsFileToUserNewTab(fileContent, _fileName); }}
[ExtensionOf(classStr(File))]final class ATLAS_File_Extension{ public static void SendStringAsFileToUserNewTab(str content, str fileName, System.Text.Encoding encoding = System.Text.Encoding::get_UTF8(), ClassName fileUploadStrategyClassName = classstr(FileUploadTemporaryStorageStrategy)) { System.Byte[] byteArray = encoding.GetBytes(content); System.IO.MemoryStream stream = new System.IO.MemoryStream(byteArray); File::SendFileToUserNewTab(stream, fileName, fileUploadStrategyClassName); } public static void SendFileToUserNewTab(System.IO.Stream stream, str fileName, ClassName fileUploadStrategyClassName = classstr(FileUploadTemporaryStorageStrategy)) { Browser br = new Browser(); str downloadUrl; downloadUrl = File::SendFileToTempStore(stream, fileName, fileUploadStrategyClassName, true); if (downloadUrl != "") { br.navigate(downloadUrl, true, false); } else { warning("@ApplicationPlatform:DownloadFailed"); } }}
Sumit Potbhare: Retail Warehousing | Wrap up | Approach to D365 for Commerce with Adv WH Mgmt Blog bot DAX Blogs 0 28.04.2021 13:12
patrickmouwen: How to Unlock Many Hidden D365 Retail Features! Blog bot DAX Blogs 0 13.05.2020 22:13
patrickmouwen: D365 Retail APIs Part II: How to know exactly what happens inside D365 Retail Blog bot DAX Blogs 0 14.12.2019 01:17
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 R2 Blog bot NAV: Blogs 0 15.05.2016 18:12
Часовой пояс GMT +3, время: 01:56.
