Старый 23.12.2008, 07:11   #1
kalex_a is offline
kalex_a
Аватар для kalex_a
160 / 19 (1) ++
Lightbulb Ну уже не знаю что и как делать ((
Уважаемы гуру, прошу посмотрите код. Что в нем не так. Ну ни как не могу скорректировать налог ((. Выдает ошибку и все тут .
switch (rDeferralsJournalTrans.DocumentStatus)
        case DocumentStatus::Invoice :
             purchFormLetter = PurchFormLetter::construct(DocumentStatus::Invoice);
             break;
        case DocumentStatus::Facture_RU :
             purchFormLetter = PurchFormLetter::construct(DocumentStatus::Facture_RU);
             break;
    purchFormLetter.specQty(PurchUpdate::ReceiveNow);
    purchParmTable.clear();
    purchFormLetter.createParmTable(purchParmTable,purchTable);
    purchParmTable.ParmId = purchFormLetter.parmId();
    purchParmTable.TransDate = systemDateGet();
    purchParmTable.DocumentDate = systemDateGet();
    purchParmTable.Num = rDeferralsJournalTrans.DocumentNum;
    purchParmTable.FactureExternalId_RU = rDeferralsJournalTrans.DocumentNum;
    purchParmTable.insert();
    purchFormLetter.createParmLine(purchLine);
    ttsbegin;
    select forupdate * from purchParmLine
        where purchParmLine.OrigPurchId==rDeferralsJournalTrans.PurchId &&
              purchParmLine.ParmId==purchFormLetter.parmId();
    purchParmLine.initFromPurchLine(purchLine);
    purchParmLine.initFromParmTable(purchParmTable);
    purchParmLine.LineAmount=rDeferralsJournalTrans.AmountCur;
    purchParmLine.update();
    ttscommit;
    purchFormLetter.createParmUpdate();
    purchParmUpdate = purchFormLetter.purchParmUpdate();
    purchParmUpdate.SumBy = AccountOrder::None;
    purchParmUpdate.SpecQty = purchFormLetter.specQty();
    purchParmUpdate.DocumentStatus = purchFormLetter.documentStatus();
    purchParmUpdate.update();
    purchFormLetter.purchParmUpdate(purchParmUpdate);
    purchTotals = PurchTotals::construct(purchTable,
                                         PurchUpdate::ReceiveNow,
                                         AccountOrder::None,
                                         purchFormLetter.parmId(),
                                         purchTable.PurchId,
                                         purchFormLetter.documentStatus());
    purchTotals.calc();
    taxRegulation = TaxRegulation::newTaxRegulation(purchTotals.tax());
    taxRegulation.allocateAmount(rDeferralsJournalTrans.TaxAmount);
    taxRegulation.saveTaxRegulation();
    purchFormLetter.initParameters(purchParmUpdate,PrintOut::Current,NoYes::No,NoYes::No,NoYes::No);
    purchFormLetter.run();
Миниатюры
Лучше сделать и жалеть, чем жалеть что не сделал
Старый 23.12.2008, 10:02   #2
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
А в выборку попадает несколько закупок? Такая ошибка происходит когда обрабатывается несколько закупок и есть коррекция налога на одной из них. Если делать "руками" в интерфейсе, то ДО коррекции налогов нужно нажать кнопку "Упорядочить" в форме обработка накладной и после этого делать коррекцию. Может, в коде нужно явно вызвать упорядочивание?
Ivanhoe as is..
За это сообщение автора поблагодарили: alex55 (1).
Старый 23.12.2008, 10:56   #3
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (11) ++++++
Да нет, не похоже...
К тому же судя по коду там одна закупка, более того - одна строка по закупке, в накладной.
Вопрос даже скорее по функционалу налогов, чем по программированию.
Zhirenkov Vitaly
Старый 23.12.2008, 11:00   #4
kalex_a is offline
kalex_a
Аватар для kalex_a
160 / 19 (1) ++
если вызвать purchFormLetter.Prompt() то все срабатывает ((, но мне не надо вызывать эту форму
Старый 23.12.2008, 11:17   #5
ZVV is offline
ZVV
MCITP
Oracle
Сообщение от kalex_a Посмотреть сообщение
Как вариант:
Ставите брейкпоинт на info.add(), либо ищете где используется метка по вашему сообщению.
Находите нужное место, откуда идёт данное сообщение.
Проясняете для себя причины, почему оно возникает.
Ищете код, который эти причины устраняет (вероятно в стеке prompt() что-то с этим делается).
Копируете в свой код.
Zhirenkov Vitaly
Старый 23.12.2008, 11:24   #6
Sada is offline
Sada
Программатор
Аватар для Sada
1,450 / 153 (8) ++++++
В промпте вроде как вызывается метод initLinesQuery(), где заполняются parmTable parmLine и иже с ними. Я бы не стал создавать эти таблы руками и тем более апдейтить их потом. Вместо промпта вызовите ряд методов, которые в нем вызываются и добавьте какой нить параметр типа showdialog, чтоб вызывать purcheditLines или нет. По умолчанию естественно он должен быть true. выже в свой парм метод передавайте false. Возможно этот способ Вам не поможет, но будет более правильным на мой взгляд.
Старый 23.12.2008, 11:27   #7
Sada is offline
Sada
Программатор
Аватар для Sada
Что то вроде
salesFormLetter = SalesFormLetter::construct(DocumentStatus::Invoice);
        parmId          = salesFormLetter.parmId();
        salesFormLetter.salesTable(salesTable);
        salesFormLetter.getLast();
        salesFormLetter.parmId(parmId);
        salesFormLetter.transDate(salesTable.InvoiceDate);
        salesFormLetter.specQty(SalesUpdate::All);
        salesFormLetter.createParmUpdate();
        salesFormLetter.createParmTable(salesParmTable, salesTable);
        salesFormLetter.initLinesQuery();
        salesFormLetter.run();
Нашол у себя в приложении кусок кода. Для примера. ЗЫ: Плюс передайте свои параметры дополнительно и может что получится.
Последний раз редактировалось Sada; 23.12.2008 в 11:31.
Старый 23.12.2008, 11:34   #8
kalex_a is offline
kalex_a
Аватар для kalex_a
160 / 19 (1) ++
в методе purchFormLetter.run() есть строка
 if (reArrangeNow)
        this.reArrange(false, false);
так вот переменная reArrangeNow имеет значение "true" соответственно выполняется метод this.reArrange(false, false); где выходит на ошибку
if (!this.checkTaxWorkRegulation())
        throw error("@SYS21628");
, а если разносить через форму заказа ("Разноска" -> "Накладная" и т.д.) то она имеет значение "False".
Старый 23.12.2008, 11:40   #9
Sada is offline
Sada
Программатор
Аватар для Sada
\Classes\FormLetter\reArrangeNow
поставьте тут точку останова
Старый 23.12.2008, 11:41   #10
ZVV is offline
ZVV
MCITP
Oracle
 if (reArrangeNow)
Ну вот вы и нашли ответ.
Вероятно, метод purchFormLetter.reArrangeNow(false) перед run вам должен помочь.
Zhirenkov Vitaly
За это сообщение автора поблагодарили: kalex_a (1).
Старый 23.12.2008, 11:42   #11
Sada is offline
Sada
Программатор
Аватар для Sada
Сообщение от ZVV Посмотреть сообщение
не не не. Помоему так низя. Нада посмотреть почему при стандартной оброботке эта переменная false
Старый 23.12.2008, 11:50   #12
kalex_a is offline
kalex_a
Аватар для kalex_a
160 / 19 (1) ++
Странно, раньше не работало. Сейчас сработало .
Спасибо ZVV
Старый 23.12.2008, 11:58   #13
Sada is offline
Sada
Программатор
Аватар для Sada
В методе reArrange выполняется ацкое количество кода Может он там зачем то нужен
Старый 23.12.2008, 12:04   #14
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Может, в настройках модуля РП стоит Суммарная обработка = Нет, и этот параметр автоматически подтягивается в форму обработки накладной. А когда вы делаете все из кода, то не прописываете, что суммарной обработки не будет, вот и ошибка.
Ivanhoe as is..
Старый 23.12.2008, 12:06   #15
kalex_a is offline
kalex_a
Аватар для kalex_a
160 / 19 (1) ++
Согласен, как я понял ( по моим раскопкам ), он выполняется когда "Суммарная обработка" не равно "Нет", а т.к. у меня всегда равно "Нет", то мне он не нужен
Старый 23.12.2008, 12:08   #16
kalex_a is offline
kalex_a
Аватар для kalex_a
160 / 19 (1) ++
Вы правы, хотя я в передаю параметр
но такое чуство что он его не видит
Старый 23.12.2008, 12:45   #17
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Эх, залезаем в код
В методе init формы обработки есть строки:
sumBy.selection(purchEditLinesForm.sumBy());
    element.sumByChanged(true);
Первая задает значение параметра SumBy. Вы явно делаете
, т.е. аналогично.
Но во второй строке запускается метод в котором:
if (_init && purchParmUpdate.SumBy == AccountOrder::None)
        reArrangeNow = false;
т.е. еще явно задается reArrangeNow = false.
Так что совет ZVV абсолютно точен.
Ivanhoe as is..
Старый 23.12.2008, 13:21   #18
petergunn is offline
petergunn
118 / 274 (10) ++++++
'Программно' функционал класса purchFormLetter это действительно 'не видит' по причине того что часть логики отночительно значения reArrangeNow отрабатывает непосредственно на форме PurchEditLines и значение reArrangeNow передается в класс в качестве параметра (в методе new() класса PurchFormLetter reArrangeNow инициализируется значением true).
Сообщение от Sada
Можно отследить что происходит при работе с формой PurchEditLines при вызове purchFormLetter.prompt() в части работы с параметром reArrangeNow :
Forms\PurchEditLines\init():
метод purchEditLinesForm.sumBy():
AccountOrder  sumBy()
    return PurchParameters::find().SummaryUpdateBy;
возвращает значение из параметров модуля "Рачеты с поставщиками". (В Вашем случае получается что "Суммарная обработка" = Нет)
Forms\PurchEditLines\sumByChanged():
void  sumByChanged(boolean _init)
else
    reArrangeNow = true;
buttonReArrange.enabled(reArrangeNow);
На входе метода параметр _init = true, после открытия формы переменная reArrangeNow = false (визуально кнопка "Упорядочить" при этом недоступна). Если параметр "Суммарная обработка" не трогать, то при закрытии формы:
void  closeOk()
purchFormLetter.reArrangeNow(reArrangeNow);
значение false уходит в класс purchFormLetter, что Вы и констатировали:
При таком раскладе конструкция:
purchFormLetter.reArrangeNow(false);
вполне укладывается в штатное поведение Ax, imho
P.S. Oops... пока излагал свою мысль Ivanhoe уже ответил в тему.
Последний раз редактировалось petergunn; 23.12.2008 в 13:26. Причина: Похожее содержание ответа
закупка, коррекция налогов, налоги, программно
Курсор перешел к следующей записи на клиенте, на сервере этого сделать уже нельзя PavelSR DAX: Программирование 22 01.11.2012 07:33
Ступор с простейшим запросом. Что-то я не знаю... vvk DAX: Программирование 5 12.02.2008 19:37
Частичный возврат по позиции отгруженой в уже закрытый период... Dronas DAX: Программирование 0 02.08.2007 11:10
Принеси то, не знаю что... Smith DAX: Программирование 5 06.06.2005 17:07
"Такая строка уже сущ." при переносе из Excel! Zelenhof DAX: Программирование 2 13.01.2003 13:41
Часовой пояс GMT +3, время: 11:55.
