Старый 08.04.2003, 16:16   #5
Yoil is offline
Yoil
NavAx Club
1,574 / 70 (6) ++++
Действительно, хелп, оказывается, полезно читать (Аттейн 3.01)
EVALUATE
Use this function to evaluate a string representation of a value into its normal representation. The system assigns the result to a variable.
[Ok :=] EVALUATE(Variable, String)
Ok
Data type: boolean
A return code which reflects whether an error occurred during the evaluation of the string.
If Ok is...
It means...
TRUE
No errors occurred during the evaluation of the string. The system assigned the value to Variable.
FALSE
Errors occurred during the evaluation of the string. The system did not modify the original value of Variable.
If you omit this optional return value and an error occurs during the evaluation of the string, a run-time error occurs. If you include it, the system assumes you will handle any errors.
Variable
Data type: boolean, integer, option, date, time, text constant or code
Any type of variable. The value of the string is assigned to the variable.
String
Data type: text constant or code
A string containing a value of any simple C/AL data type.
Navisioin 3.7 -> 3.6 Кактус NAV: Администрирование 4 04.12.2006 16:39
Управление складом->Подборы->Корректировка vasiok NAV: Функционал 0 10.03.2005 16:36
Import Consolidation from File <Attain> uk NAV: Программирование 1 26.03.2004 17:13
Товар - > формула расчета прибыли? Timur Kaumov NAV: Функционал 0 22.07.2003 14:37
Трюки программирования (A->B->A) SlavaShevtsov NAV: Программирование 4 13.03.2003 09:18
Часовой пояс GMT +3, время: 01:49.
