Старый 07.04.2007, 12:51   #1
SysDictCoder: Reflection with the Dictionary
Источник: http://sysdictcoder.wordpress.com/20...he-dictionary/
In X++ it is possible to write code that inspects the structure of other X++ code. This is sometimes called reflection or meta-programming.You may wonder why you’d want to do that. Reflction is a very powerful tool and opens a wide array of possibilities. Without it some things would be very hard [...]
За это сообщение автора поблагодарили: kashperuk (2).
axStart: Synchronizing dictionary gives unclear errors Blog bot DAX Blogs 0 15.12.2007 01:11
gatesasbait: On data dictionary synchronization errors Blog bot DAX Blogs 0 29.11.2007 00:53
SysDictCoder: Moving the blog Blog bot DAX Blogs 1 05.07.2007 01:56
SysDictCoder: SafeMap Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 19:42.
