Старый 13.03.2008, 19:05   #1
axStart: When is my Label file updated in AX?
Источник: http://axstart.spaces.live.com/Blog/...C0A0!269.entry
If we look at our label files in the AOT we see 3 different extensions for our labels
·        ALI Axapta Label Index
·        ALC Axapta Label Cache
·        ALD Axapta Label Dictionary
The ALD file is readable/edible whit a text editor. General speaking you only need the ALD file. When the AOS is restarted the ALI and ALC will be generated on the fly.
Next a developer will create new labels. These labels will be stored in the ALI file.  Not yet in the ALD file.  When the final AOS will stop. AX will update the ALD file this way. It will copy the ALD file to an ALB file. Next the changes in the ALI file will be stored in the ALB file.  Finally this ALB file is placed back in the ALD file and the ALB file will be deleted. (HINT: make the ALD file read only and you will see it your selfJ)
When your AOS has creased the changes are not stored in the ALD file. Even when you start and stop the AOS again the file is not updated. To solve this issue start an AX client search for the label in the Label editor. Next stop your client and the AOS. Now the label file is updated.
Старый 13.03.2008, 19:18   #2
Нет, не в ALI, а в ALT-файле.
ALT-файл содержит изменения в метках до тех пор, пока эти изменения не будут перенесены в ALD.
Старый 13.03.2008, 19:27   #3
блин, не могу воспринимать такие предложения. Тяжело структурировать, что ли?
  1. developer will create or edit new labels.
  2. These changes will be stored in the ALT file. Not yet in the ALD file.
  3. When the final AOS will stop, AX will update the ALD file this way:
    1. It will copy the ALD file to an ALB file.
    2. Changes in the ALT file will be added in the ALB file.
    3. Finally this ALB file is placed back in the ALD file and the ALB file will be deleted. (HINT: make the ALD file read only and you will see it your self)
  4. ДОБАВЛЕНО: при следующем запуске AOS "обнаруживает", что дата и время модификации ALI, ALC файлов меньше, чем дата и время модификации ALD, и пересоздает индексы.
За это сообщение автора поблагодарили: Logger (1), alex55 (1).
Старый 14.03.2008, 10:39   #4
гляди ка. мужик исправил
Старый 16.02.2009, 19:23   #5
alex55 is offline
alex55
224 / 145 (5) +++++
Пару раз сталкивался, что данный механизм перестает работать (DAX 4.0). Например, в каталоге приложения висели *.alb файлы, которые не удалялись после рестарта AOS. Вновь добавленные метки в *.ald не попадали вообще. Возможно это как-то связано с изменением меточного интервала для данного меточного файла.
Помогло удаление *.ali, *.alc для нужного меточного файла и рестарт.
Старый 27.01.2010, 19:41   #6
alex55 is offline
alex55
224 / 145 (5) +++++
Для 3.0 SP2 KR2 при работе в трехзвенке при такой последовательности действий .ALD может не обновляться.. Способа гарантированно получить обновление меточного файла из кэша в трехвзвенке пока не обнаружил.
Старый 28.01.2010, 11:59   #7
EVGL is offline
EVGL
4,445 / 3001 (0) ++++++++++
А AX2009 научился выдавать разным программистам одни и те же номера для меток. Весело потом искать и исправлять. Вообще, AX2009 разучился с ними нормально работать.
За это сообщение автора поблагодарили: AlGol (1).
Старый 28.01.2010, 16:29   #8
AlGol is offline
AlGol
277 / 93 (4) ++++
Вот... я всегда знал, что моя нелюбовь к меткам была оправдана.
Старый 28.01.2010, 22:09   #9
AX2009
Гость
n/a
Подтверждаю, было один раз, в причинах не разбирались.
Еще как-то раз несколько меток просто пропали. Вероятно из-за VCS.
alb, alc, ald, ali, alt, label, метки
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
axStart: InfoPath with default AIF file inbound offline Blog bot DAX Blogs 0 20.05.2008 19:05
Часовой пояс GMT +3, время: 00:14.
